.50 A/R 57 trim T3/TO4e too small?
HolyShiznit
Car: Working on my car
I have an offer for a brand new turbo with the specifications of a .50 A/R compressor and .63 A/R turbine 57 trim stage III wheel. My problem is this: Is it too small? I want to be around 250ish WHP at 8-9psi. Dunno who else to ask.
Thanks in advance.
SingleCamSam
Should work perfect.
erich
Perfect sized for higher boost. 8-9psi is at the bottom end of the efficiency range of that turbo, but it'll be fine.
HolyShiznit
So I will be at the bottom end of efficiency range but have lots of room to grow. Thanks Erich!
Nathan
You might also want to look at the 50 trim...its much more efficient ;) I doubt you'd be complaining about either one though!
