SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sat Apr 30, 2005 7:40 am
90% of all aftermarket wheels if not more are lug centric.
Any mass marketed wheel is lug centric. Hub centric rings can be found in the aftermarket if you look hard enough.
Only special wheels from top tier companies offer metal hub centric rings, and only vehicle specific aftermarket wheels(Rays for Z33 for example), which are rare and expensive, are hub centric. Build to order units from HRE, BBS, etc. can be hub centric.
The reason most mass market wheels are lug centric is too accommodate for different hub bores. If Honda and toyota and hyundai all have smaller hub bores than Nissan, then Motegi (for example) needs to make their hub bore at least as big as the biggest hub bore found on any vehicle in a given bolt pattern.
