5" tach install need a little help
paintballer419
Car: 03 Evo 8: perrin dp, greddy 3 inch, ix diverter valve, apexi intake, hks 264 cams, hks rs intake, TRE stage 3 tcase and competition clutch flywheel and stage 4 clutch
o just cut to the chase, ive tried hooking it to the ecu's rpm sensor or what not, and to wire which which a timing light is connected under the hood. is there any way to not spend anymore money, and or not splice into all four distributor wires?
fast_s13
whats wrong with the stock tach?not rice enough....anyhow its the yellow /red stripe wire on the dash harness
