LayNLow240 »
https://forums.nicoclub.com/laynlow240-u33346.html
Tue Jul 03, 2007 9:14 am
i was thinking that it could be your syncros are shot, or your 4th and 5th gear sensors are dead, but seeing your last post makes me wonder.so check your MAF, make sure it is plugged up and make sure it is clean. go buy some MAF cleaner and clean it to be sure.if your problem presists get a known working MAF and try it on your car. if the problem is still there, check to make sure none of the MAF harness wires are cut/split/frayed and make sure they are properly shielded.
