So the transmission is still in gear, but giving it gas doesnt accelerate? When you hit the gas does the engine rev without speeding up the car or does the engine not rev? Give a detailed description of what happens with the engine and the speed of the car.victormotorsports wrote:Even if I hold the gear in it doesn't pop out but it goes in neutral
This post has horrible english / punctuation / grammer, etc... from what I think you are saying, it sounds like your clutch is slipping.victormotorsports wrote:the car when it shuts down it does nothing at all till I push the clutch and release then it reengages and runs again but will not run under a heavy load. like full on acceleration from a stand still. at 55 mph. the car shuts down.
