5 speed transmission
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
odpl_Timmay
I ran across a 5 speed transmission for sale that came out of a 280Z and was then used in a 510 wagon behind a L18 motor.  Any one know if this would fit in a '79 620 w/ a 1950cc engine?
Thanks!
IMH
With some work it will.  The Z 5 speed is longer and will require modification the the mount and shortening of the driveshaft.  It will place the shift lever a bit farther rearward than I'd like in a truck.
odpl_Timmay
Good to know, thanks!
mklotz70
Not to take anything away from this board, but you'd find a lot more info on that subject at http://forum.ratsun.net/index.php
Do a search there....the question has probably been answered several times.  It just may fit quite easily if your rig already has a long tail transmission.
and1er23
Car: 2000 infiniti i30
not sure
and1er23
yea your right, i found some info to
Return to “Datsun 620”
