5 speed swapped my vert, I need wiring help asap please!
Clark W. Griswald
Car: '93 240SX Vert/ '87 Toyota Cressida
So I just got back from on hour drive to get this swap done in a shop and I have problems with my reverse lights and my top. I ran the green wire and black wire from the reverse switch to the spliced brown/yellow+ blue/green from the inhibitor plug and also the green/white from the inhibitor plug. I ran the green/white wire to the green wire on the switch and the brown/yellow+blue/green to the black wire. I disregarded the other wires on the harness completely and theyre sitting there cut off. The only things I have connected to the transmission are reverse switch and VSS. What have I done wrong?
Clark W. Griswald
Nevermind guys I figured it out on my own. The wires in the writeup were incorrect to the ones I had to use.
sainifabulous
Car: 1992 240sx HB - 1991 240sx HB DOHC, SR20det waiting to be dropped in.
samething happend to me the colors werent matching up lol
Clark W. Griswald
Im very happy I got the wiring straigetened out. I forgot that I had to bench bleed the slave cylinder though so I may have to go back and do that but it doesnt seem to be giving me trouble.
