5 speed swap wiring: help me please!
fiznat
Car: Grown up :(
Ok this is driving me crazy. I've read up basically everywhere I can find, and I'm pretty sure that the reason my engine is not cranking is because I never looped/jumpered the neutral saftey switch when I did my AT-->MT swap.
Thing is, I simply CANNOT find the right wires that I need to splice together. I've searched the FSM, asked lots of people etc etc. To make matters worse, in the effort of neatness I cut off the automatic transmission plugs from the back of the fuse box and taped them all up. They look good when all tucked away, but now it is impossible to find the correct "plug" simply by a description of the plug's original orientation. Here's a pic to show you guys what I mean:
As you can see I really have no idea what wire went to what anymore.
Now, I need to know: is the neutral saftey switch or whatever located on that (rear) side of the fuse box, or is it attached to the DRIVER'S side of the fuse box, like here:
I am thinking that it could be this plug also, that I am holding there (black/yellow and white). Note that the plug is turned around backwards to more easially show the wire...
What do you guys think? Any kind of info regarding wire orientation or color would REALLY be helpful. Note this is on a 1993 automatic S13.
Thanks guys!!
fiznat
Car: Grown up :(
another view from under the fuse box:
you can see the little tab there that I think the plug originally mounted on... Is it possible that the plug to the left in this pic that is disconnected (this is that black/yellow and white plug from the other pic) that that plug used to be under the box, and that is the plug I need?? Argh you can see how wire colors would really be helpful...
GnarKiller
hey fiznat im not sure if its any different for an s13 but the one i slpiced together on my s14 is the one that was directly on top with one black/white wire and one black/red wire going into the plug...
like i said im not sure if they are the same but that should help out some.if you have any more questions feel free to ask...
Zach
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
im not srue where to lead you on this one other than try heavythrottle.com they ahve a write up on the swap. sorry i couldnt help anymore
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
go in the convertable section. tankawa akiato or however you spell hit has a great write up, with all the pictures you need. i used his info to do mine.
fiznat
Car: Grown up :(
yeah I checked that also.. he talks about the location of the plug but never mentions the color of the wires...
fiznat
Car: Grown up :(
Here is a (crappy) pic of the wiring diagram for the starting system. Am I looking for the 2 wire plug that goes into the inhibitor switch? ...Or is it something else?
small version:
huge version:click for large version
Seems to make sense, as it looks like in this diagram that the inhibitor switch will only complete the E12 circut if the car is in neutral or park. So B/Y B/W it is? Ill look for it in that bunch of wires in a couple mins.
ca18datsun510
reach under the box, its stuck under there. there is a plug with 2 wires, i wanna say yellow and brown, they are fat wires, only 2 on this plug. jump them together. id take a pic for yo but my car is burried under 8 million feet of snow.
574-240sx
Car: Nissans, Toyotas, Subaru
This should help. Once you jump these your car should start. You won't have reverse lights though untill you wire up the sensor. I took a few pics a while ago to help people with the location.
http://www.imagestation.com/album/?id=4289753059
574-240sx
Hope these work
ca18datsun510
ah, there ya go, i guess im color blind, but those are the ones i was talking about.
fiznat
Car: Grown up :(
FOUND IT!, and the car CRANKS PERFECTLY NOW!!
The freakin wire (black/white and black/yellow as noted in the diagram above) was HIDING from me underneath the fuse box. I found it by following the black/yellow wire from the starter, through the 1st plug (E19 on the diagram), and then through the INSIDE of the freakin fuse box. All this time I was convinced that it couldnt have been that wire because it went inside the fuse box, but apparantly it just goes through the box itself and never connects to anything. I found the plug and the other wire waiting for me on the other side there (see pic) mocking me.
Ah well, thanks for everyones help!!
drifter_for_life06
Car: Daily: '16 WRX
Exocet
glad to hear your car finalyl cranked over
