5 speed swap speedo problem
johny1111
I just got the 5 speed transmission installed and now my speedo seems to be showing double the speed. What can I do to fix it?thanks
johny1111
come on guys, someone must have an answer
i searched quite a bit and i couldnt find info i'm looking for
PhopsonNY
Car: 1989 Nissan 240SX
Maybe the new transmission had a bad speed sensor?
Maybe you can test the sensor output.
I cannot remember the voltage range, but maybe check your FSM.
good luck
johny1111
So u're sure that this shouldnt happen when doing auto->manual swap?
johny1111
I guess I should have mentioned that I used S13 transmission for the swap into an S14.
I read that the speed sensor is causing this problem. Is this the case? SHould i invesnt in one?thanks
Nismo_Dj
Car: 97 red se kouki
not to hijack ur thread but i just got my 5 speed swap as well and my engine light is on, is urs on as well?
bps71
Car: 96 240sx w/ sr20det
just had mine done and if it hit 65 it shut off thinking it was doin near 120.. had to have wire cut to it now no speedo.... have 5spd speedo on the way... will tell you if it helps
johny1111
bps71, do u have s14 with s13 manual transmission?
nismo, yes i have bunch of codes
0802 - crank pos sensor 0804 - A/T diag line 1203 - overrun clutch solenoid valve (A/T control unit detects improper voltage) 1204 - T/C clutch solenoid (A/T control unit detects improper voltage) 1205 - line pressure solenoid valve (A/T control unit detects improper voltage)
Is there a way to fix all the A/T codes without getting a manual ecu? Or is it just best to get manual ecu?
Also, how do i get rid of the crank pos sensor code?
popogto
i think its the speed sensor issue. i have a s14 transmission in my s13 and the speedo is showing half. didnt want to mess with the speedo gears so i just got the apex RSM
PhopsonNY
johny1111 wrote:I guess I should have mentioned that I used S13 transmission for the swap into an S14.
I am pretty sure the s14 and s13 speed sensors give off different signals.You will have to do a search to confirm this.
Niclas_AB
I guy told me he had solved this problem by installing an resistor(hope thats the correct name) at about 1000ohm , never tried it myself tho.
bps71
yes Jony1111 i do .... howd u guess
PhopsonNY
this link might help
zerothread?id=168894
