apollo500 »
https://forums.nicoclub.com/apollo500-u40738.html
Tue Apr 21, 2009 8:59 am
I have a 96 OBDII, I used the S13 trans. It bolted right up, only thing i had to do is to drill a hole for the CPS and make a custom bracket to hold it in place. So to answer your question the S13 trans works with S14s. But i did have a small issue regarding the installation of the driveshaft, there was some rubbing between the trans and driveshaft, but after a little grinding it fit and the car runs fine. Have had the trans in for 7 months, 3,500 miles and no problems.
