no, I did not. What will that do not disconnecting the TPS???94_240sx wrote:Good to hear that. When you adjust idle, you are supposed to disconnect TPS and reconnect afterwards. I hope you did that.
I think idle will go up a little if you plug in. Check the FSM. If I remember correctly, you unplug TPS, adjust to 500-600 and plug back in. That way idle will be around 600-700 range. 800 is a little on the high side.BiXLL wrote:no, I did not. What will that do not disconnecting the TPS???
