5-Speed Swap Cost
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
Greetings my fellow vert-brethern,
I bought the boy a 2000 Honda Prelude yesterday with a 5-speed. I had forgotten how much fun it was to drive and now I've got to teach him how to drive it!
I've threatened for years now to do the swap but really don't have the technical chops to pull it off myself. So my question is - if I buy all the parts and garage them for a bit what's the consensus out-of-pocket i'll spend for parts - knowing that this will vary for quality and any "deals" I might run into.
The next step is to con one of you to come to Raleigh and help me! :naughty:
Also, this board has kinda slowed down a bit. Any Spring/summer projects coming up for anyone? PEACE!
biggie
You can browse my thread, some costs may be in there.
my-vert-5spd-swap-and-other-work-t472033.html
But rough estimates:
5spd transmission $75-$100, may get lucky though
New slave cyl at parts store $15
Master cyl and line - $20-$25
5spd driveshaft - $20-$40 hopefully
Clutch kit - really varies - ebay Exedy stock replacement - $100
May want OEM throwout bearing and pilot bushing - $70
Shifter, shifter trim, etc - OEM would be $50 or so, goes up if aftermarket shifter
New OEM rear main seal and transmission seals - $40 or so probably
transmission oil - 2.5qts depends on brand
S13 5spd clutch and brake pedal - $50 or so
That's about all off the top of my head.
cmkelly
2006 Acura TL
Thanks biggie, hope all is well in Clemmons.
http://i213.photobucket.com/albums/cc4/ ... relude.jpg
biggie
Oh no, blinded by a honda.
cmkelly
2006 Acura TL
We had a bunch of cars on the list - Nissans, Toyota, Acura, etc. so we weren't looking for a honda - the Prelude was one of them and then all the peices fell into place. Other than the boy not knowing how to drive a stick :>)
biggie
Should be easy to teach on at least.
cmkelly
2006 Acura TL
He learned in one day.
Ilya240sx
Car: 1992 240SX Convertible
  • - Flywheel 14lb $220
    - Exedy OEM clutch kit $110
    - SS braided line $30-40(16.95 for a pre-bent one hardline from NISSAN Dealerships)
    (I dont like the look of SS Clutch lines, they go from point A to B in the shortest distance and IMO looks bad)
    - Pressure Plate To Flywheel Bolts $6
    - Flywheel Bolts x6 30$
    - Bellhousing bolts [email protected](washers = ?)
    -Transmission front and rear seal and paper gasket~= 20$
    - Clutch Master & slave 40$
    - Engine Dust Plate 40$
    - Transmision Cross Member
    - Pedals
    - Big Rubber Boot
    - 5 SPeed driveshaft
    -Transmission ~= $60
Front Seal Paper Gasket # 32112-08U01 $4.50
Top Shifter Gasket 32516-03U11 $5.36
Rear Oil seal 32136-U0100 $8.74
Front Seal-oil 32114-Y4000 $3.71
Manual Transmission Flywheel Bolts - 12315-42L11/ 6 needed
Manual Presure Plate Bolts 01121-00772 / 6 needed
Engine / Bellhousing Bolts
Bolts = 08131-0601A / 60mm length / 4 needed
Washers = 08915-2401A / 4 needed
Bolt = 08131-0701A / 70mm length / 1 needed
Washer = 08915-2401A
Bolts = 08124-0301F / 35mm / 2 needed
Nuts = 08911-2401A / 2 needed
Bolt = 08124-0601F / 65mm / 1 needed
Nut = 08911-2401A / 1 needed
Bolt = 08071-0251A / 25mm / 1 needed
Starter Bolts = 01121-03751 / 95mm / 2 needed
Lower Shift boot 32862-V5001
shift boot 96935-40F10
Shift Knob from dealership was $30
Hope the list helps, over all I paid about 700 dollars, but I did buy almost everything from Nissan Dealership, and I am glad because doing the swap, I had everything I needed after I bought all the bolts, well I lied, I had to go to ACE and buy one bolt, but I dont remember which one.
