5 speed swap clutch pedal question
JDMskrilla
Car: 1997 240sx se
So I am doing my swap this weekend on my s14 if I can get a clutch pedal. I have searched everywhere for a s14 pedal and all I can find is new ones for around $150. My question is about using the s13 pedal, I know I have to use spacers but has anyone experienced issues or any problems with a s13 pedal in a s14. I would rather pay a lot less for an easy to find s13 pedal than shell out 150 for a new s14 one.
DLYNNW
Car: 89 nissan S13.5 97 Kouki s14 06 toyota Bb
yeah you can use everything from a s13 to swap it did it in my friends 97 kouki s14
Jonnie Fraz
The difference is that on the S13 chassis the spacers are welded to the firewall and on the S14 the spacers are welded to the pedal assembly. Go to Home Depot and get a 3/8" pipe nipple 6" long and cut two spacers 1-1/8" long out of it. Sandwich them in between the S13 pedal assembly and the firewall. Do not forget the upper bolt. You are done.
JDMskrilla
Car: 1997 240sx se
ya that was the route I was going to take but then I found an s14 pedal, thanks tho...
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
i used a nissan pulsar clutch pedal assembly and bolted right in. same deal as the s13 pedal as far as the shims go though, good luck! i only paid like 15 bucks at pick and steal.
