574-240sx wrote:I converted my second 240 less than 2 months ago. Do you have an idle problem, such as not ideling down untill you come to a stop for a few seconds?
LongIsland240 wrote:Yeah, it does hang around 1,300rpm for a while, but then gradually decreases to a normal idle....I had just attributed it to leaving the auto ecu running things, perhaps i'm worng, but anyways....btw, thanks a lot, it was your picture of bypassing the P/N switch that finally got her started- nobody else really described it well.
cyrus240sx wrote:does anyone know the easiest way to get all of the parts for an s14 5 speed swap?Should i go to a junk yard or nissan dealer or what?
240sxHitman wrote:OH ok, as u can see from my profile im from hempstead. Do you go to DPA?
sil80drifter wrote:my 90 240 has been doin that weird idle thing for a year now. I think maybe the cold-idle sensor maybe messed up but i'm not sure where it is or what to do with it (except replace it when i find it). Like I'll drive aroudn and then put it in neutral cruising at 40+mph and the idle will go down to 12000 or 1300 and stay there until i tap the brakes or slow down to a stop. it's a little annoying, but not too bad. Oh, btw this was a M/T car to begin with, so not an Auto ECU issue for sure.
sil80
