5 speed A/T EX35 4th gear RPM- Weird.....
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
AWGD8
Car: 2008 EX35 AWD JOURNEY
Hi guys,
So I was merging on the highway this morning and there was a semi that I was trying to beat while merging. I was at 3rd gear and floored it then shift to 4th gear. The car was pulling very hard (70+ MPH) on 4th, then I noticed the RPM on 4th seems to get stuck at 3K RPM and very very very slowly creeping up pass 3k and above... It just weird, i cannot remember if this is normal or not?
I got used to seeing the RPM bounced from 7K (2nd gear) and bounced back to 5K RPM after shifting to 3rd gear. I expect shifting to 4th the RPM is at least 3.5 -4 RPM but maybe not? Even while cruising at 4th gear at 65MPH and I tried to floor it a bit , the RPM jumps to 3K rpm and stays there longer and if I press the pedal longer then it slowy start to creep up to 3k + rpm . I mean slooooowly....
Can anyone pls. see if this is normal for the EX35 5 speed transmission?
Thanks a lot!
CDNicecube
Car: 2010 EX35 Journey+Tech+Navi
It seems like mine does stay at 3000 rpm at about 65mph in fourth , but I never checked at 70mph so I'll Check for ya, stay tuned
It might be part of the normal behaviour..... due to rev matching?
AWGD8
CDNicecube wrote:It seems like mine does stay at 3000 rpm at about 65mph in fourth , but I never checked at 70mph so I'll Check for ya, stay tuned
Yeah! Seems normal I guess... Thanks!
CDNicecube
Yes, I tried it this morning. Went up to 70-75mph in fourth. It was indeed at 3000 rpm and in fact went down to 2900 even at 75mph.. Odd. but such is life.
AWGD8
CDNicecube wrote:Yes, I tried it this morning. Went up to 70-75mph in fourth. It was indeed at 3000 rpm and in fact went down to 2900 even at 75mph.. Odd. but such is life.
Thanks for verifying this. :dblthumb: I thought it was just my imagination. :gapteeth:
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
dang! Now I need to try .... :O
AWGD8
XIS wrote:dang! Now I need to try .... :O
:gapteeth: I am curious to see how the RWD EX35 behaves. ;)
XIS
Mine acts the same... it's a very long 3rd gear.
:dblthumb:
AWGD8
XIS wrote:Mine acts the same... it's a very long 3rd gear.
:dblthumb:
That is good to know that it is normal. Have you timed your rwd ex35 0-60? Just curious what the real world number for the RWD.
XIS
I have never timed it...
I might be getting too old!
Eamess
Car: 2010 Infiniti EX35 Journey
I experienced this too. Any solutions??
AWGD8
Eamess wrote:I experienced this too. Any solutions??
The only solution is to use a Manual mode.
Eamess
AWGD8 wrote:The only solution is to use a Manual mode.
Thanks!!
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
