Jesda wrote:For 88-91, the upper center console plastics were very brittle if exposed to heat. They cracked and broke on my first 929. The solution is to buy a glue-on wood trim kit.
I had minor electrical issues on both. The first had a brake warning light that came on when I used the brakes despite there being no brake problem. Car #2 had hazard lights that came on when I used the horn. Also, sometimes I had to jiggle the key on that car to get it to start. Lock cylinder was probably worn out. Nothing major, just minor nuisances.
The rest of the issues I had were all age related. I came to rely on mazdarecycling.com to keep my cars going.
After owning a Q45, I still have an inexplicable fondness for the 929. I think I need to buy another to get it out of my system. Its definitely a fun car to own and drive.
my dash plastic cracked near the drivers door when i slipped on ice and smashed my knee on the dash, a small crack, nothin too bad. i did end up cracking a peice in the middle slightly when i was putting my dash back together. all in all it is cracked and is brittle, do you have a pic of this "wood" trim ?
i replaced my lock cylinder a while back
i outfited my car with Alpine as soon as i could but the stock system was pretty cool.
i also had the brake light warning stay on on forever but after replacing all the bulb it still stayed on so i cut a peice of electrical tape to cover the annoying light perfectly and it has bothered me in 2 years.
a very good car none the less, i still need to buy a 929S to get it out of my system, a real fun car to drive.
the platform is HC and its called a Luce in Japan, bigger brother and parts sharing with the RX7...
