Mine wouldn't come with vice grips until i notched the adapter bearing so it would crush then i put a socket on crank with breakover bar and was able to twist out with vice grips. Another thing not listed anywhere is that you will need to take out the cable that goes to your key release. I popped out the white piece with a flathead on the ignition by pulling top cover off and looking to see where the cable went. I have an s14 it may be different but just a heads up.odmoht wrote:use the vice grips to take out the AT adapter.
saves you a lot of time and head ache!!!
just twist it out and you are done with it.
