smocan »
https://forums.nicoclub.com/smocan-u33734.html
Fri Feb 29, 2008 8:20 pm
What more do you want, that link shows exactly how to do it.
i dont have one saved anywhere but look on 240sxforums, i believe its in the diy section. And i know for a fact that if you google correctly, you should find plenty of info.
Its really not hard, i've changed hubs, unbolt calipers. Pull off the rotors (use the screw holes to loosen the rotors if they are stuck on, they are press fitted) Then take the cover off over the hub nut and crank it off, replace hub and do reverse.
