billabong093 wrote:Ugh, so off to find j30 axles. And your saying the front hubs wont fit so ill need conversion hubs, i've only heard of the ichiba ones so i guess ill be looking for those as well?
ive found everything needed to know just by searching this site or using google. read the links i sent ya, theres lots of good info
this was pulled from the link i sent you.
The conversion on S13's is not as simple. If you want to follow the path of using all OE parts, you will need the S14 upright, along with the S14 ball joint. The ball joint is necessary for the reason that the shape of the S13 ball joint prevents it from working properly and creates a extremely unsafe vehicle to drive.
The alternative to doing all of this work, including trying to source out used components that are not damaged or worn is to use a 5-lug conversion hub. PDM Racing offers a few alternatives, one is pictured below
