Clatch wrote:Those 5 lug spacer add-ons are going to add rotating weight - the worst kind of weight you can add - which will reduce your performance.
true, however the weight is not as far from the center of the rotation as many other parts of the wheel, rim wight and tire weight would start to add up much more then the weight of the spacers. The weight does need to be considered elsewhere though, its much easyer to rotate mass then to make it reciprocate. Unsprun mass is very detrimental to handling... think about the reasons we have springs and shocks on cars, with no suspention the car would bounce, well the rims have no suspention. its important durring acceleration and cornerting that the tires be kept incontact with the ground as much as possible, with a heavy rim being acceletated upward when it hits a small bump in the road its going to stay off the ground, or on the ground but unloaded, for longer, what good is a larger contact patch if its not making contact.( aslo what good is a larger contact patch if your spacer brakes and you crash at 60 into a wall?)
