wankelTII »
https://forums.nicoclub.com/wankeltii-u48978.html
Fri Dec 15, 2006 8:41 pm
If you have the money then just call up JRZ and get them to send you a set of 2-way coilovers. You can pick your spring rates for $30-$50 a spring from eibach, i would start with something like 600lb front and 400lb rear assuming you might still drive the car on the street once in a while. The JRZ's will allow you to adjust the bound and rebound separately and give you much more flexability than any 1-way coilover from Tien or HKS. You can also get them re-valved if you find yourself riding around with the rebound maxed out all the time. Plus if you ever do any track events JRZ offers full track side support to anyone who buys their product. For anyone who doesnt know, they are the sister company to Moton and are just as well made but alittle less expensive.
But with JRZ coilovers, decient spring rates, some adjustable suspension components, and some stiff and possibly adjustable sway bars you can make the car do anything you want. You can make it stick, or you can make it slide, but if you dont know what you are doing it will handle like crap so read up! You are going to want to be able to adjust the front and rear toe, front and rear camber, just go as far as you can with the caster without causing any unecessary wear and the rest of the adjustments will be in the coilovers. If you know what you are doing with this stuff you can make the car handle as well as your average Grand Am Cup car. Find a really nice book on suspension!
