5 lug question again..i've seached..
Bobby_Wu
i know there's alot of information on this topic ...but the information is so scattered that i can't made heads or tails with it...
before i goto the local nissan dealership and order my hubs i want to clear up a few things..
i have a 1995 240sx Non-ABS 4 lug setup...i want 5 lug setup
from what i can understand...all i need are the 5 lug hubs from a S14 240sx...and it's a direct swap..just the hubs..no spindles...
the picture below shows the base model 4 lug hub from a S14 in the middle and nice shiny new one is from a 5 lug hub from a S14...i do not have ABS..and i think the teeth on the 5 lug hub is for the ABS...am i correct???
Thank you
C-Kwik
yes, the teeth are for ABS. There should be versions without them available. Just get the cheaper one.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
wow, im gettin ready to do this too! base models SUCK!
-Dan
Bobby_Wu
C-Kwik wrote:yes, the teeth are for ABS. There should be versions without them available. Just get the cheaper one.
Thanks C-Kwik...i'll do that..
240sx2nr95 wrote:wow, im gettin ready to do this too! base models SUCK!
-Dan
Yeah i know what you mean Dan ... i want big wheels and 300zx brake upgrade on all four wheels...i didn't want to redrill my rotors for 4 lug application...that just doesn't sound right...especially for something that's suppose to be stopping your car....i'm sure drilling for 4 lug is fine but not for me...
i'm not entirely sure about the 300zx upgrade in the rear...i know it's not neccessary but it would be nice...
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
How do you get those dam things off? My FSM is horrible at giving directions. What are exactly the spindles?
Bobby_Wu
nnkfws333 wrote:How do you get those dam things off? My FSM is horrible at giving directions. What are exactly the spindles?
i believe you remove the round cap thingy at the end of your asle with a small screwdriver and there's a big nut in there you have to undo...not sure though but i'll let you know when i do it...i'm going to try to get a digi cam to document since there's not all the much info in this swap
Dano
i still have to buy the hubs and try to find some SE rims and then ill do my 5lug /300z upgrade all at once...
-Dan
Bobby_Wu
240sx2nr95 wrote:i still have to buy the hubs and try to find some SE rims and then ill do my 5lug /300z upgrade all at once...
-Dan
i'm doing the 300zx upgrade with the 5 lug conversion. i haven't found wheels yet .... do you think i can find some steelies that will fit...i might need spacers....
Dano
im lookin for the OE 16" SE rims myself... but i cant find any cheap enough. Guess no1 with aftermarket rims has a big enough heart to help out a fellow S14 owner that just wants theyre old wheels sittin in the back of their garage.
-Dan
Bobby_Wu
240sx2nr95 wrote:im lookin for the OE 16" SE rims myself... but i cant find any cheap enough. Guess no1 with aftermarket rims has a big enough heart to help out a fellow S14 owner that just wants theyre old wheels sittin in the back of their garage.
-Dan
i just want something cheap too...if i can fit steelies on there that'll be great .. this guy at my work has a brand new Jag XK8...the rims on that thing are bad a.s.s....i want them..
Dano
i just want OE 16s...
-Dan
bigE
Car: Anything dealing in cars.
I have a couple of sets of 5 lug hubs, used. 250 plus shipping per set. All you need is the hubs for S14's, no spindles.
Eric
