tramp_drift240 wrote:but here's my question:
im currently thinking about just getting the Ichiba coversion hubs. meaning i can just bolt them on (front and back) onto my existing spindle assemblies.
if i do that, what rotors would i have to get to make them work with my stock calipers? s14 SE rotors?
and if i go Ichiba, what would i do about aftermarket LSD's? are there any OEM alternatives? would i have to go ahead and swap my whole differential/axle/hub assemblies to get a better LSD option?
should i go ahead and do the 300zx/s14 5-lug/front uprights swap?
basically, i dont know what combinations would work for a 5 lug swap onto an s13, i need to know what is possible so i can figure out what im able to choose from.
if your doing a 5 lug on your car, all you have to do is redrill your rotor to 5 lug or use maybe use the se rotor (not sure though).
as far as the rear for the lsd it shouldn't matter, but if your talking about vlsd then you may need a different axle. the q45 rearend will require you to use the q45 rear hub/appropriate axles/diff.
i think you mean the rear upright. its up to you but if you are then you might as well get the whole 300zx rear hub (make sure its from an N/A). the q45 also have this aluminum thing that you can use for a rear upright.
as far as the front i think your limited to aftermarket to bolt on and the s14 and i believe someone did a j30 require some other parts or mods. theres various 5 lug combo specially the rear (s14 se, 300zx n/a, q45, aftermarket) maybe others. you might find more if you search around.
hopefully that help
