5 Lug Hub (knuckle) Swap Q - New Rotors Needed?
s14=pimpin'
Car: 1995 Nissan 240SX SE S14
hi guys,
My mechanic is telling me I need new rotors in order to perform the 4 to 5 lug hub swap. Is this true? I always thought it was a straight swap, calipers and rotors were interchangeable, no? Any help or suggestion, pointers, things to look out for, would be much appreciated, thanks
Jubs180
Car: 91 Nissan 240SX 5spd Hatchback
if you have 4 lug right now, yes you will need new 5 lug rotors
the hubs will swap no problem, I would advice on changing your wheel bearings while you're at it.
but the rotors will not.since the rotors have either 4 holes or 5 holes
the actual size of the brake is not changed I think, so the calipers can be used on the new rotors with out any problems (I think)
hope this can clarify a bit
-Dan
s14=pimpin'
thanks bro, was hoping to get away w/using my current rotors (yes, I have 4 lug right now) since they are almost new. Another question, if I have a muffler with a 3" inlet, can I still use 2.5" piping, or will I have to use 3". Can get a good deal on a brand new muffler with a 3" inlet, but I want 2.5" piping for the cat back.
thanks again
