5 lug conversion?
Trigger
hey will the front hub work from a 300zx for a 5 lug conversion...all i ever see you guys talking about is s14 front and 300 rear...this would be some good info for me because i can get my hands on a set for cheap. thank you
Dori Dori
Car: Cars of course
Nope, sorry.
FYI, the s14 5-lug works for the rear too. Also, the front hub doesn't bolt to the s13 spindle (if you have an s14 you have nothign to worry about)...you have to use an s14 spindle. Lastly, the s13 LCA ball joint doesn't work w/ the s14 spindle, so you'll need to swap the ball joints as well.
