5 lug conversion
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
i used the little search button and couldn't find anything
im trying to take off the 5 lug rear hubs on my s14, i took off the 4 bolts behind it but it still wont come out. are there any other bolts im missing or should i pull harder?
redlineracer
Car: 1991 nissan 240 sx coupe
i took out the axel and heated the hub with map gas and tapped it out it took a while but it did work
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I didn't do the five lug conversion but I did remove my 4lug hubs when I did my rear brake convesion and I ran into a problem like that. Once you remove the four bolts the entire assembly, hub, spindle and dust shield should just fall apart which is what happened on my passenger side but my drivers side was a different story. It would not come apart, man I beat on that thing like crazy. I did some searching and found out that this is common because of the heat generated over time some spindles/hubs will seize up and not come apart. I had a buddy at a dealership use a press to get mine apart.
-RJ-
sweet thanks guys, so i guess i just need to pull harder
-RJ-
alrite i got it out, i had to use a breaker bar to take those hubs out
94_240sx
Car: 94_240SX
Good job.I would think PB Blaster, mullet & breaker bar will get the job done for sure. They've never let me down.
-RJ-
i cant take out the rear hubs!!!
5 Skware
Car: 1993 Nissan 240 SX and 1992 Honda Civic Hatch
so did you get it or not?
-RJ-
the front is on but not the back lol
positron1
Dude I'm telling you the heat got to it. Press 'em out to be on the safe side! Mighty Thor'in on 'em with a hammer is gonna ruin your hubs.
