MIdnkight-lude »
https://forums.nicoclub.com/midnkight-lude-u15551.html
Tue Sep 04, 2007 9:14 am
no real company makes a 5 lug conversion kit. they are generally parts remove from other vehicle that has the same hub make up and adapted to the current car. So as far as something working to be used, good luck. Maybe in two/three years, there will be another car produce that will use similar suspension setup as the Versa, and the 5 lug parts can be adapted pretty easy but currently your luck out.
Now if you ask why there is a company making a 5 lug conversion for the 240sx, it is because there is such a huge market of people doing the 4lug to 5 lug conversion, and the shortage of part that a company produce the conversion kit. It been a while since i read, but i believe most of the part were either new 240sx hubs or even hubs from the skyline in Japan.
I as have a feeling you wanna switch you lug on account of the rims. Yes the selection for 4 lug rim is horrible, it is even worse for our bolt patter, which is 114.3 but if you had a bolt pattern of 100, we would have access to way more rims. Sigh, i own a prelude with the same bolt pattern and have look into doing this too. It a total custom setup, and no one would have no clue where to start, begin, or end. Cheers.
