5 lug conversion
240DRFT
the search isnt working right now, and i know theres several different ways to do the swap...so for the front on a s13, can u use a 300zx's front uprights and 5lugs hubs? do u need anything for the front? thanks.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Heres the link to the site I found really helpful:
http://sillbeer.com/5lugswap.php
Perhaps something like a parts list and quick run-through could be put in the 240sx.org FAQ? That is, if there isnt already one and I just missed it...
BTW, the search not working is pissing me off too.
240DRFT
hmmm doesnt mention anything about using z32 parts for the front. i c if u use s14 front parts u have to get the s14 bushing pressed into the s13 lca...is it like that for a z32?
240DRFT
heres the parts...do i need anything else?
thanks again.
Juujai
if you're doing it on an s13, you need s14 knuckles/spindles s14 se hubs. itll drop right on but you need the s14 ball joints pressed where the s13 ball joints are. the shock mounting bolts from s14 are bigger than s13. you'll need to redrill the s13 shock or get a spacer.
300zx front will not work.
kane2g
Car: 92 240sx 95 240sx
or go to 5lugsleves.com and get the sleves and save the shocks :P
