5 lug conversion spindle question...
95jordan240
Car: 1995 nissan 240sx
well i have been searching and cant find this but i finished my five lug conversion and when tryin to connect the rod for the steering to the spindle i got stuck...when trying to tighten the nut the bolt just spins withit...do i need to go rent some tool or wat??i got the left one on fine but the right just wont work....
onosqv
Car: '92 240sx Vert
if you are talking about what I think you are: your tie rod end could be busted, it shouldn't move at all when tightening.
ckf
Car: 1990 nissan 240sx
you should have to just put a jack under it and lift it up to put some pressure on it to keep it from spinning. somebody please correct me if im worng.
gumby74
That is generally what has worked for me in the past. Put some pressure on the bottom of the tie rod end while tightening.
95jordan240
thats wat i tried and kept spinnin out f***in wierd...just went and bought a new tie rod end and worked perfectly...
thanks for the help though guys...now i can start my five speed conversiion
