5 lug conversion question
Sr20detNESS
Car: '92 240sx fastback redtop sr20det
Anybody here ever converted to 5 lug by using attain's hubs or pdm's hubs? how are they? do u recommend them?
thanks
574-240sx
Car: Nissans, Toyotas, Subaru
My friend used attain hubs and it was much easier than what I did. He also spent alot more too. I used S14 spindles and hubs in the front and S14 ball joints. The rear I used Z32 n/a hubs.
sXi
574-240sx wrote:My friend used attain hubs and it was much easier than what I did. He also spent alot more too. I used S14 spindles and hubs in the front and S14 ball joints. The rear I used Z32 n/a hubs.
574.. you cars looks way hot with the z wheels. I am looking to do a 5 lug swap too. could you give me more info on that please?
if it's possible, could you do a write up ? because the article i saw on this forum still confuses people. Thanks in advance!
SeVa-S13
Car: '05 GTO 6spd
Stop posting this in the wrong forums. Your first post got moved to the right section for a reason.
574-240sx
Thanks. I crashed my car about 2 weeks ago. I will try to do a write up because everything will be transfered over to a coupe this winter.
Basically the 5 lug swap was pretty easy. I will try to work on a write up soon. The rears bolt on and the front is a little more complicated.
