5 Lug conv Difficulty lv
A.K.A. Tokio
Car: 89" 240sx Hatch
Hey i have a 1989 240sx Hatch. was wondering how difficult it would be to do a 5 lug conv with front z32 breaks.
Components:
Ichiba 5 lug hubs http://www.phase2motortrend.com/ic5lughubcok.html
300zx front aluminum 30mm calipers
z32 to 240sx conversion SS lines for front
Experience with cars:(to base difficulty lv)
A friend helped me do a motor swap/coilovers (he's the expert)
I did FMIC install and replaced my T2 gasket (this i did by my self)
btw im not too tech savvy with cars so step by step is greatly appreciated.
Other parts ill be getting are Brembo blanks for front and rear. Rears i have to get s14 sized blanks right? because ill be usuing the stock s13 rear breaks
Hawk HP pads all round.
Did my own share of research on this but couldn't really dig much up. unless all 5 lug conversions are the same no matter what the car then theres a few youtube vids i saw.
Sileighty_85
Car: 1991 180SX
If you are installing Z32 Brakes you need the Z32 Rotors, they bolt right up after the 5 lug swap just remember to get the correct sized rotor for whatever size caliper you have.
S13 and S14 brake rotors are the same (minus the 4-5 lug diff), ABS is the only difference and the rear caliper on the S14 uses a different Ebrake cable design
So if you went 5 lug in rear and using the stock caliper then get the S14 rear rotors
A.K.A. Tokio
Thanks. as for the installation of the hubs them selves how difficult is it. any chance i would $%^# up my car
Sileighty_85
Car: 1991 180SX
Ichia Front bearings are a Hit or Miss,
I would recommend buying some REAL OEM bearings installed into the hubs
But the swap is fairly easy, the rear is time consuming
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
ichiba is bolt on 5 lug for a S13, the Z32 brakes fit fine, you need
Loaded calipers
Rotors
Conversion brake lines
loaded Z32 or Q45 rear backing plates
Z32 2+2 ebrake cables, or standard z32 cables routed a different way with a bracket stay welded onto the cars body
Z32 BMC with one of the flares cut out of your s13 BMC and pressed in.
Now you can use OEM s14 or z32 NA rear hubs for the rear 5 lug conversion and
S14 LCA or S13 LCAs with S14 LBJs pressed in
S14 Knuckles
S14 front shock or coil or drill the hole bigger and use the larger S14 bolt or buy the hole spacer kits.
TheRealNap0le0n
Car: 1998 q45
the hardest part is bleeding the brakes really...
i got ichiba front bearings IIRC... the $150 ones on ebay... they have lasted a year no problems
A.K.A. Tokio
Btw 5 lug conv/ z32 brake upgrade went real well. had a few difficulties here and there but i got it done. Cept one problem are my new rims for the front dont clear the calipers lol just ordered some spacers
