Perrenial Badass »
https://forums.nicoclub.com/perrenial-badass-u98460.html
Thu Jul 03, 2008 1:01 pm
Well technically speaking, more lug nuts can more safely hold more weight. Which is why a school bus has 10 lugs, whereas the short bus has only 6. As we all know, tards generally weigh 40% less than normal people.
But seriously, weight is generally why a certain lug number is chosen. For most of the early Zs... Nissan saw fit to equip NA 84-85 Z31s with four lugs. They are heavier than earlier Zs, so I'd say that weight isn't a good reason to swap over. The second consideration is wheels. 5 bolt are easier to find, especially in a zero offset. But I've seen plenty of 4 lug wheels that would fit, so that might not be enough reason. The third reason I can think of is the brakes. There are alot of cars with a 5x114.5 bolt pattern, such as the Z32. So there are plenty of upgrade options available.
