5/94 Q45 rear brake pads
nandrolone
I just changed the rear brake pads on my 5/94 Q45. However, it had a brake sensor on the passenger pad. According to the parts store it should not. Thsy stopped putting the sensor on 2/94 models. Thanks for the help.
qship96
Car: 1996 Infiniti Q45
Did your replacement pads come with a electrical or mechanical {metal clip} sensor?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If you don't have the wire (and it wasn't removed before you purcahsed the car or shorted), then you shouldn't have the sensors. If you have the sensors, you will see a display light in the dashboard.
nandrolone
It does have the sensor. However, it was made in 05/2006. I tied the sensor to the body.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
nandrolone wrote:It does have the sensor. However, it was made in 05/2006. I tied the sensor to the body.
Huh?
In any case, you have the wrong pad, or should have employed the sensor. Your call if you are attentive to your car.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
What is the brand of brake pads you bought?
