5.5 Maxima manual trans owners please read. Q?
jwitt418
Car: 2003 Nissan Maxima SE 3.5V6 6spd
Just bought a 2003 SE, the shifter does not seem to go into gear as smooth as it should.
Is this common?And recommended serivce?Can it be lubricated? And where?
1/2 mechanically inclined, so please explain in detail if possible. Thanks to all.
jwitt418
bump
Timmy98max
Car: 98 nissan maxima white 5 speed
check all your clutch lines for leaks and see what the free play in your pedal is if thats all good then you may need to adjust the linkage or just replace the clutch you can also check the shifter at its base and put new grease there
Presscott707
Car: 1999 Maxima 5spd
does it grind at all? because you may just need to have the transmission flushed.
jwitt418
It doesnt really grind, it just feels like there is a little too much resistence going into its gear position.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Mine is a little notchy too. They all do it. Redline MT90 is supposed to be good in there but I haven't done it myself yet.
