deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Wed Mar 08, 2006 7:16 pm
It all depends on how much welding you want to do to your crank, if you want to actually build up the journal diameter well be my guest
Your looking at a lot more than 325, your going to need an expert machinist that is very familiar with his tools and equipment. The most tedious portions of the job will be aligning all of the journals, sounds easy right, they have a machine for that? Like I said, if you want to get it done you need the best machinist/shop you can find, it will cost.
This is done often for stroking of oem cranks, but even in that situation you are working with equal or smaller rod journal dimensions, so a lot less welding in general. You want to avoid any welding you have to do to a crankshaft, and building up the journal diameter is going to take a lot.
If your looking for some interesting affordable domestic alternatives, you could look into getting unfinished sbc parts from an aftermarket manufacture. You will need unfinished journals so that they can be fit to your application without crank welding. The same thing would go for those ford modular rods, find them in semi-finished form. I can tell you it is easier to find these this way in cnc aluminum and titanium than it is to find forged H beam.
Btw, with that 5.4l rod length the ford modular 4.6/5.4l/6.8l pistons would suit appropriately in the ka24, 90.2mm bore. These pistons were the "big secret" like a year and a half ago than no one told anyone about. That was untill it was found that various aftermarket manufactures had listed these parts with 33.5mm compression ht. vs. the 31mm that they actually are, good for strokers and hybrids.
