cnichols »
https://forums.nicoclub.com/cnichols-u493.html
Thu Jul 31, 2008 1:55 pm
I see you're in Bowling Green, KY. If you know Chris Long, definitely pick his brain.
But, to answer your question, yes, the 5.3, being a member of the LSx family can use the GTO pan, LS1/LS6 intake manifold, etc. T-56 will bolt up, motor mounts as well. If I hadn't found such a good deal on my LS1 and been worried about the small weight difference, I would have gone this path as well. The one thing you might have to do besides change intake manifolds, is swap accessories as well. In the end, however, I still think the 5.3 is a VERY good alternative to the LS1 as it can also be bored out to a 5.7 in case it ever lets go.
