maik21 wrote: 1-stock rearend its good.... i read they are rated at 400lb of torque. maybe u can switch to some lsd or weld it.
2-u can use a single one from a grand marquis or some ford setup. u will need the piece that fits on your transmission and then weld the other side to the piece on the rear end.
3-because there is no kit for swap, u will need to mount engine and transmission first and then take lenght size for proper fitment. dont worry, try to do one step at once.
1- coo..might do the 9" rear..we ll see how the 240 one will do. i have a kazz 2way lsd, should be okay
2-i was wondering which year marquis?
3- for sure was gonna test fit everything to make sure it has good positioning. from there was gonna measure for the shaft. just cant wait to have all my parts and tools for the build. i will deff be taking my time, but not too long as i want to have it finished up by the start of summer. thanks for the info bud..keep it comming
Modified by arabdrifter at 10:01 PM 5/20/2009
