scruf1986 »
https://forums.nicoclub.com/scruf1986-u3282.html
Fri Feb 21, 2003 7:14 pm
Yeah. Every single speaker I have ever put into my 240 had to be cut or bent or drilled and the wire connectors had to be bent as well. So if thas what you have to do thas what you have to do. I recommend that you cut excess metal and drill wholes if you have to. It gives it a tighter fit which will make it not rattle.
