4x4 hardbody coilover conversion
808fronty
Car: 2001 frontier SE
-does anyone have any info on this kind of conversion being done?
-will frontier aftermarket coils work w/coustom fab?
truck: 91' hardbody extra cab.w/trailmaster 3" lift, 31x10.5x15 tires.
any input you want to give me would be cool :cool:
THANKS!!!!! :dblthumb:
808fronty
I have found a thread on 4x4parts.com fourms.
The guy who has done this conversion has used the following parts....
-FOX shocks-2.0 pro series coil over/10" travel shocks w/piggyback res. (dont know if he used 5/8" shaft or 7/8" shaft) - $385.00
-EIBACH-700lbs springs - $65.00
ALL MOUNTS WERE CUSTOM FABRICATED!
But as far as i know the top mounts were mounted 8" above the frame and the bottom mounts were fabricated with a steel plate across the LCA and the lower mount(which is a sheared shaped to go over the half shaft)welded onto the plate. As for the shocks going through the UCA he has cut out to make clearance of about 1/4" from the spring. Yes, he has beefed up the UCA unknown of how though. Yes he did remove the torsion bars! =)
I'm going to try it out!haha hopefully it turns out the same.
but i'll try copy and post his picks of his setup.
808fronty
sry website for parts is.
www.offroad-engineering.com
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Cool information. I'd love to turn my Frontier into a rock crawler but I have to keep it my daily so no serious mods for me. :(
808fronty
awww man.
you should but just a small lift and some 31's like my truck. =)
I use it as a daily driver too. haha
I'll post some pics of my trucks.
808fronty
http://www.4x4parts.com/ubbthreads/show ... =7&fpart=1
HERE IS THE LINK TO THE COILOVER CONVERSION THREAD!!
ENJOY!! :biggrin:
