Yes it is like 10 minutes from my house. I was going to go wrecking yard hoping as soon as i found out that they fit. Shelton has quite a few yards to choose from so im sure i will find a set. Thanks for the reply.dogred wrote:No problem, they used the same body panel for the 4x4 and 2wd.
Side note, Have you been to All West Coast Auto wrecking? It is down close to you right?
You nailed it. 15x8 w/3in backsapce. I figure with a slight pull and the flares i will be golden.flinterman2000 wrote:15X8 shouldn't be too wide unless the dish of the rim is all on the outside.
Remember the flares are formed to suit the original shape of the fender. Pulling of the lip will change the contact area at the top of the flare and will not look uniform.seven-20 wrote:I figure with a slight pull and the flares i will be golden.
Look for a set for me also, please. I have trouble getting time to get down that way, and the yards up here suck. If you find some 15 or 16 inch wagon wheel rims let me know, I am looking for some for my rear rims. Just need a pair not a full set. Last yard I went to only had 1 nissan truck, a D21.seven-20 wrote:
