Zion8561 »
https://forums.nicoclub.com/zion8561-u28751.html
Mon Oct 13, 2008 8:07 am
My truck has 156K on it. It makes a loud rattle on startup for a couple seconds until oil pressure comes up, and then it settles into a constant lighter rattle. Not sure how long it has been doing this, it was like that when I bought it at 147K. Not much wear on the metal portion of the guide and the outer part of the timing chain though (I am going to install new guides, tensioner, chain, oil pump, water pump, T-stat).Good point about the strainer, I didn't think about that last night. I know the filter will take out the plastic particles before it gets to the bearings, etc but if the strainer gets clogged then I am SOL...I don't think there is much of a chance of fishing the guide peices out since it is a rear sump.
