4x114.3 to 4x100?
vwluv10338
Is there an easy way to convert the lugs to 4x100 to open more wheel choices without going through all the trouble fo the 5 lug conversion? When you do a Z32 brake upgrade you have to get the rotors drilled to fit the 4x114.3 studs but can to get the piece that the studs are in redrilled with new studs put in?
Eric
SloMoe
Car: Fast Cars, Music, Girls
You might want to use the search function before posting. This has been talked about in previous threads.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
BuudWeizErr
You want to go to 4x100?
Why.
4x100 is what Honda Civics and Kias have.
Do 5 lug.
240_Keyy
Car: '90 240 Fastback
word to what Buud said...
vwluv10338
I would go 5 lug but I thought the whole swap with new ball joints and what not would be more expensive than just redrilling for a more common bolt pattern.
Eric
Onizuka
come on, how could you posibly want 4x100? yes they make alot of cheap arse, crappy wheels for that size but then again, most of those wheels are universal 4 lug (4x100 AND 4 x 114.3). It would cost you more to go to 4x100 cause of all the custom stuff you would have to fabricate (custom hubs at a machine shop). If you were going that rout it would still be better (and cheaper) to go 5 lug. If you dont want to swap out the front suspension, get aftermarket 5 lug hubs for the 240, yes they DO make them. (http://www.jspec.com or http://www.phase2motortrend.com can get them) For the back you just need either s14 or Z32 rear 5 lug hubs.
vwluv10338
J-Spec Tuner wrote:come on, how could you posibly want 4x100? yes they make alot of cheap arse, crappy wheels for that size but then again, most of those wheels are universal 4 lug (4x100 AND 4 x 114.3). It would cost you more to go to 4x100 cause of all the custom stuff you would have to fabricate (custom hubs at a machine shop). If you were going that rout it would still be better (and cheaper) to go 5 lug. If you dont want to swap out the front suspension, get aftermarket 5 lug hubs for the 240, yes they DO make them. (http://www.jspec.com or http://www.phase2motortrend.com can get them) For the back you just need either s14 or Z32 rear 5 lug hubs.
I have read the SCC z32 brake article and have searched the topic here and you are telling me all I would have to do is buy Z32 brakes and rotors and then 4 to 5 lug conversion hubs? I can just put those hubs on without using the S14 spindle? What about the rear brakes? All I need is the hub and not the whole forged rear which would require different shock mounts?
Eric
Onizuka
thats what im saying, aftermarket 5 lug front hubs and s14/z32 rear 5 lug hubs and thats it.
vwluv10338
Awsome. That is so much easier that I think I will actually do it. Changing all the suspension parts seemed a little too complicated except in the rear. If I can find the whole aluminum upright for the rear I think I will put that in to save weight.
Eric
Onizuka
that will still force you to use very expensive hybrid rear suspension peices, just keep the stock uprights.
RobDET
Car: Cars
J-spec you just make me laugh loudly at work with that $#!+ Funny stuff man!
vwluv10338
Whap hybrid rear pieces? The only thing that I would need that would be different on the rear would be the lower shock mount. And after looking at the prices on the conversion hubs ($500) it is now seeming like a better idea to just get the new ball joint in the front end put in and just use the stock 5-lug hubs.
Eric
