I have bought a QX4, 2001 3.5L, 1 month ago and I'm pretty impressed.
Changed many parts(suspension, cooler oil seals etc) and all is good now, except 4WD shift light. At first, when changing the selector button, everything was ok. Then I think I messed up the procedure for 4LO to 2WD.
Here's what I have:
-No 4WD warning light on(sometimes it does turn on on hard acceleration on wet surface then turn off at the next start)
-4LO light is ok and will engage, 4H light is ok and will engage.
-When I turn it on AUTO, the lock flashes, front and rear wheels are steady green.
-When I turn it on 2WD, the lock is flashing, the front wheels are flashing, and the rear wheels are steady green.
What does it means? Still on 4WD?
I really need help here. Infiniti took a look, 3 hours, found no faulty parts. They say it could be anything and they need more hours to continue searching...125$ per hour...
I have read the manual, tried the procedure, but nothing changed.
Is there a way to reset the system?
Any ideas?
thanks all !!!
