4WD question
exvin
Car: 2000 Nissan Pathfinder
Hey All
I have a 2000 pathy and it does not have the button switch to 4wd (4H, 4L), I have the gear lever. Now my question is how do you get to 4H? I know how to get to 4L, which is when I pull the lever down....Am I doing something wrong because the level head has the set up as
2W (i think) N 4H 4L
Or something in that order, but I can only pull it down one and then to neutral and 2WD
Help
bmlawless
Car: 1999 Infinity QX4
I'm no't sure that I am following you entirely. It sounds like you are saying that you can get to "4H", but you wrote "4L". Under normal operation, you should be able to pull the lever from 2H to 4H while stopped or driving under 45mph with no problems.
To move from 4H to 4L, you need to be in neutral and stopped or moving less than 5mph. To get out of 4L, the same rules apply, put the transmission in neutral and shift to 4H.
exvin
I will check it when I get home tonight but I think you understood what I was saying and I understood what you are saying
jimmyzzer
Car: 1999.5 nissan pathfinder
it should be2h4hn4low
exvin
ok so if it is
2h4hn4low
How do I get from 2h to 4l and 2h to 4h? The lever seems to only go down to neutral and then one below
Is it two pulls of the lever or one? If I have to go to 4h or 4l do I have to be stopped or in neutral, I usually make a complete stop and then switch, but again I can pull the lever down once and it stops
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
are you pushing down too? What you need to do is to get to 4HI from 2HI it goes
2HI4HIN4LO
Do not push the physical lever down (towards the floor) you just pull it about 1 inch or so back, towards the back of the vehicle. Thats 4hi. Then to get into N you have to push down and pull back, same to get into 4lo.
