4wd light on in Qx4
mkimister2
Car: 1990 300zx na
So i finally got my qx4 started and running but the 4wd light is on. I am hoping it is only disconnected wiring but dont know. I did the diagnostics for the 4wd light and I got a t1-t2. I dont know how infiniti converts the flashes to numbers. Is it a 1 and 2, or is it a 12? Here is a video of the light blinking to help since its hard to explain. http://media.putfile.com/4wd-diagnostics Thanks, Andrew
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
That first blink is just the "start signal" to show you that its gonna start spitting out codes. So you really only have a code 12... which of course (you already knew this) is the rear revolution sensor.. you could PROBABLY confirm this by doing a transmission diagnosis and seeing if you come with the same conclusion.
