nickelghandi »
https://forums.nicoclub.com/nickelghandi-u215217.html
Thu Mar 15, 2018 6:31 am
Hello all,
I have been with this issue and the shop since they replaced my transmission. After the replacement, my 4WD light would come on intermittently and the lights indicating which drive mode I was in would go out. This usually happened on long highway trips and was difficult for the shop to replicate. It also was fixable by shifting from 2WD to Auto and back a couple times or it would just go away on its own while driving or on the next restart.
Then I noticed it once in 4WD. When it occurs, it moves shifts back to 2WD and 4WD is unusable until the error clears itself once again.
It has not yet happened in 4 Lo, and it won't because I won't use 4 Lo now that I am aware that it tries to switch back to 2WD. Imagine if I were in drive in 4 Lo and it tried to switch back...
As of 3/10/2018, the light came on and is constantly on. I have no 4WD.
Before, I was able to run the diagnostic and it would blink some random code that did not make sense with other codes and then clear itself up for a while. Now, I can neither read the code nor clear the code.
Every time I have taken it to the shop (which is where it has been more than in my driveway since the transmission replacement) I have them try to diagnose this to no avail.
I do need a Universal joint on the front drive shaft, and my shift lock solenoid (thing that lets you shift when you press the brake) does not work, but I do not think those are related.
I have seen the older threads, and tried their fixes to no avail. The transmission fluid is fine as is the transfer case and differential fluid. I have no leaks.
I am thinking possibly the TCM or even an ABS sensor, but I don't know and don't have the equipment to diagnose. I would take it back to the shop, but I have given them almost $500 in diagnosis at this point and they have returned nothing. They are an extremely reputable shop and have lots of experience with Nissans. I also know the owner and head technician personally so I doubt foul play or incompetence.
Is it worth it to take to the dealer or will they (and this seems likely from previous experience) just tell me some ridiculous repair that costs like $3,000 to do and won't even fix the issue?
I am at a loss and considering selling this vehicle because it has seen less than 2000 miles since August 2016 when the transmission failed and was replaced because of other issues mentioned in other threads and this 4WD issue.
Anyone had this issue before? How did you fix it? Anything guys...
