Quincy48 wrote: ↑Fri Nov 09, 2018 8:25 am
... I have a 2013 infinity m37s with just over 61,000 miles and these pesky lights wont go away. ...
How long have you had the car for and how long have the lights been on for?
Has the car had any brake work done on it (especially an entire system fluid flush) in your ownership?
Can you confirm that the tires on all 4 corners are the same size and manually check their pressures are relatively equal.
This question is in line with alignment. Have you had it checked?
The C1138 code points to either a bad 4WAS control unit or a bad ABS module...or a communication problem. If I were a gambler, I'd go for the ABS module first.
Thanks for providing the code btw. It helps tremendously
