4thgen vq3.5 swap atuo
scuba420
Car: 1999 nissan maxima 93 octane only
can u get the 6 speed auto transmission off the 6th gen and put the tectronic in 2 and use a trouqe converter ty
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
6th gen manumatic transmission is only 5 speed. The Manual is 6 speed.
Basically, yes it would be possible. But it would require quite a bit of work. The only thing I can see being straightforward would be mating the bellhousing to the engine, which should bolt straight up. Everything else would require some work and/or modification.
I'm at work so I don't have a lot of in-depth tech info with me, but I'd imagine trans mounts will different (and remember that this isn't just your usual 4th gen auto-to-5speed swap--that trans never came in that car, so neither set of mounts will work) axles/output shafts will be different, you'll need the correct TCU and other electronics,
Also remember that the 6th gen auto has a gated shifter with the current gear displayed on a single-character digital display in the dash (which you could in theory mount wherever you want it).
audtatious
2004 to 2006 is a gated design. 2007 is not, but is a CVT only transmission.
