4th gen engine swap
Discuss topics related to the VQ series engine.
NismoX
what engine can possiably fit in a 4th gen???? and is it worth the time and the money to do an engine swap?
NismoX
japmaxse wrote:First it's deff worth it, with the swap low 13's 1/4 are easily attainable.Any 2000-2006 FWD Max or Altima engine will fit with only some slight modifications. Or you can go Hybrid, 4thgen heads and 3.5 bottom Like I did. Pics of my swap herehttp://www.cardomain.com/ride/530800
Everything you need to know about the swap is herewww.maxima.org Go to the ALL Motor section.
you think the 3.5 engine can fit with the 4th gen auto transmission or not?
NismoX
japmaxse wrote:Yup it sure can, beware tho my Auto had 130.000 on the odo and I toasted 1st and 2nd in one day under normal driving conditions. So I went for the 4thgen 5spd.
my tanny is basically new. cause it has maybe 50k on it now.
Modified by NismoX at 10:12 AM 3/1/2007
marstorah
Car: '99 maxipad
I heard the power gained in 5th generation maximas in the 3.0(not 3.5) was from the better designed intake manifold. if so, can I put this Manifold on my 99' Maxipad and expect big hp gains?
NismoX wrote: you think the 3.5 engine can fit with the 4th gen auto transmission or not?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
marstorah wrote:I heard the power gained in 5th generation maximas in the 3.0(not 3.5) was from the better designed intake manifold. if so, can I put this Manifold on my 99' Maxipad and expect big hp gains?
Not "big" gains, but it is definitely worth the install.There's an excellent how-to for installing the 5th gen variable intake on 4th gen written by a member here:zerothread?id=121423
jmeister
Car: 1998 Maxima SE
MinisterofDOOM wrote:Not "big" gains
With a 00VI & weak tune my gains were 20wtq from 3500-4800 RPM and 15whp peak at redline. That not big enough for ya?
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
