loystock »
https://forums.nicoclub.com/loystock-u10145.html
Tue Aug 03, 2010 10:28 pm
Check your battery connections are clean and tight and voltage >12.5VDC. If not, try to jumper the car and see if it starts, If engine runs, then you need to replace the battery.
If car still won't start, you may have a problem with fuel delivery, ignition or engine control/sensor. Also check the main engine harness ground points (2 ea near intake plenum close to cylinder #2) are clean and tight. When was the last time you replaced the fuel filter? Is the CEL ON? Do you have any maintenance record of the car?
